J_herb's avatar
J_herb
Explorer II
Sep 04, 2015
real slow ACER netbook
I have a ACER netbook with windows 7 and 280 GB HD and 2 GB of memory,
it's so slow it won't even go on the internet. I check the task manager and it shows nothing running when it's just sitting their.
It shows the CPU from 5 to 15% and the physical memory from around 87 to 94% and doesn't change. Will a bad memory make your computer real slow ?
  • J herb wrote:
    I'm using MS essentials for anti virus and malwarebytes right from day one. The Acer is 3 years old and this started about 8 months ago and been sitting for the 8 months as I bought a new HP laptop and just wanted to see if I could find what's wrong with the Acer.
    I will try the things that you suggested. Thanks
    Adware, malware and virus would be the most likely culprits that will cause a good working PC to suddenly no longer work correctly or as fast as it used to.
    You need to boot to "safe mode" in order to really run anti virus/malware/adware scan and clean up.
    Some anti virus programs can also slug a PC, there may be an optional scan mode which continually scans the drive that may be using up resources or memory..
    Clip coupons? If so many of those couponing sites are full of Adware, they tend to dump lots o junk on your PC turning it into a slug.
    To full of a hard drive can cause a PC to slow down, take a look at how much room you have left.. If you have 20% or less unused space on your drive you need to move files you want to keep to an external drive.. Any other document files you don't need or want to keep you can delete them (remember to empty the recycle bin when done otherwise the files will still be on the drive taking space).
    While I would agree that 2gig of Ram is a bit light for Win7, it really isn't the problem since you noticed it getting very slow only a few months ago. Adding memory to a Netbook most likely will not fix the slow and a good chance that Netbook is maxed out in RAM for the system board BIOS and most likely is not upgradeable.
  • I'm using MS essentials for anti virus and malwarebytes right from day one. The Acer is 3 years old and this started about 8 months ago and been sitting for the 8 months as I bought a new HP laptop and just wanted to see if I could find what's wrong with the Acer.
  • A netbook with only 2gb is going to be a bit slow but if you have not done so get a copy of advanced system care and have it scan your computer for registry errors, performance issues, malware, internet issues.
  • J herb wrote:
    OP here, I'm at home and on DSL and my HP laptop and my tablet work great. Thanks
    I am assuming it was not always "slow", right?
    Pretty good chance you have malware and or virus..
    With nothing open or running you should have no more than 1% for CPU usage..
    15% or more with no programs open is your problem..
    Check your processes, note the processes that are using the CPU..
    Then look up the processes and see what they are.
    Heck, I am running a P4 at 2.8ghz that I am typing this on and with only FireFox running I am only using 1% to 3% of my CPU.
    Have you tried to reboot it?
    What about virus or malware?
  • OP here, I'm at home and on DSL and my HP laptop and my tablet work great. Thanks
  • Ka Ron wrote:
    How are you connected to the internet?
    Are you using park WiFi or home internet?
    If you are using park WiFi some RV parks pay for internet by bandwidth and will slow down service if there are a lot of people using the service
    Here is an article about campground WiFi which might help...WiFi FAQ's
  • How are you connected to the internet?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
