- Tom_M1Explorer
mike-s wrote:
LMR-600 is 50 ohm and can not be used. RG-11 is quite a bit thicker than RG-6. RG-6 will work fine.
But if you really want to waste your money, you want hardline or LMR-600. - mike-sExplorerNone of the wire runs on an RV are long enough to worry about which cable to use. RG-11, RG-6, RG-59, the difference is mice nuts.
But if you really want to waste your money, you want hardline or LMR-600. - Big_KatunaExplorer III’ve used 150’ to get to the RV park cable input. Pathway X2 worked fine.
- theoldwizard1Explorer II
westernrvparkowner wrote:
RG11 is used primarily for very long runs. For most RV use RG6 is fine.
Concur !
Use the Snap-N-Seal compression connectors. RG6 have a blue seal and the part number is SNS1P6. They do require a special tool to install. - 2naEagleExplorer
RG11 is used primarily for very long runs. For most RV use RG6 is fine. RG11 isn't generally available at your local hardware store while RG6 is. I sure wouldn't spend a dime more for RG11 unless you are looking at running distances in excess of 200 feet.
Has anybody used this cable?
Quad-Shield RG11 Heavy Duty Coax Cable w/ Weather Boot Connectors Indoor/Outdoor
Thanks!
Yeah, I need it for extended runs on my DISH Playmaker. Most of the places we camp it's pretty difficult to get a signal, so 100' gives me more options on where to place it, with minimal line loss.
Thanks for the replies!
Does the playmaker work OK at the long distance with the RG11? - Range_Maggot_BoExplorer
Thanks!
Thanks for the replies! - Big_KatunaExplorer III bought a 50’ and 100’ for my Pathway on $10 ext cord reels.
- westernrvparkowExplorer
Thanks! - TodduptonExplorerFor what exactly? Satellite?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
