Range_Maggot_Bo's avatar
Oct 18, 2018
RG6 Cable
Has anybody used this cable?
Quad-Shield RG11 Heavy Duty Coax Cable w/ Weather Boot Connectors Indoor/Outdoor
Thanks!
  • mike-s wrote:
    But if you really want to waste your money, you want hardline or LMR-600.
    LMR-600 is 50 ohm and can not be used. RG-11 is quite a bit thicker than RG-6. RG-6 will work fine.
  • None of the wire runs on an RV are long enough to worry about which cable to use. RG-11, RG-6, RG-59, the difference is mice nuts.
  • I’ve used 150’ to get to the RV park cable input. Pathway X2 worked fine.
  • westernrvparkowner wrote:
    RG11 is used primarily for very long runs. For most RV use RG6 is fine.
    Concur !
    Use the Snap-N-Seal compression connectors. RG6 have a blue seal and the part number is SNS1P6. They do require a special tool to install.
    Thanks!
    RG11 is used primarily for very long runs. For most RV use RG6 is fine. RG11 isn't generally available at your local hardware store while RG6 is. I sure wouldn't spend a dime more for RG11 unless you are looking at running distances in excess of 200 feet.
    Yeah, I need it for extended runs on my DISH Playmaker. Most of the places we camp it's pretty difficult to get a signal, so 100' gives me more options on where to place it, with minimal line loss.
    Thanks for the replies!
    Does the playmaker work OK at the long distance with the RG11?
    Thanks!
    Thanks!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
