Gdetrailer
Apr 08, 2021Explorer III
Shouldn't show up as a u1 drive or any other storage..
Should show up as a "Media player device" (MTP).
Good thing there is no format option, you don't want to format MP3 players as that can really mess them up as sometimes there may be folders or files the player uses in that space.. Which may be what happened to your player.
Did you try plugging the player into a USB charger and then try to turn it on? Battery may be dead and the player may have froze..
Try a standalone USB charger and allow several hrs time to allow battery to charge up.
See HERE
Sometimes that will wake up a non responsive MP3 player.
All else fails, try a reset of your player, follow instructions HERE
More info on your player see HERE
If nothing above works, the player firmware may have been corrupted..
You might try downloading the firmware from the above site and see if you can reload the firmware.
If all above fails, it may be time to replace..
See HERE
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
