Rmack1's avatar
Rmack1
Satellite TV cable strange corrosion
I had to troubleshoot my Winegard Traveler satellite dish as my DirecTV receiver wasn't communication with it.
I found corrosion on the cable out from my SWM unit, which I had to install to make my Genie receiver work. There was lots of corrosion in the fitting, so I thought I found the problem. I replaced the whole SWM unit and made a new fitting, but it still didn't work.
I found another very corroded fitting inside the 'power to SWM' port on the power inserter, which is the other end of the cable coming out of the SWM. The thing is; I understand how the outside fitting could have got compromised, as it is outside in the weather, but the power inserter is inside, right under the TV and surrounded by other electronic stuff. In fact, right above the 'power to SWM' is the 'signal to IRD' which is connected to the receiver, and it's fine.
I live in a very dry climate. It's been raining recently, but my trailer is dry. A month or so ago, the wind blew open a skylight and let a little water fall on the couch, but it dried out quickly through slightly open vents with the drapes open to let the sun in. It's at the other end of the trailer from my fittings anyway.
Very little humidity at limited times over less than four years wouldn't seem to be enough to cause the extent of the corrosion I saw. I needed a new power inserter and a new fitting, and everything is fine now.
Is there some kind of harmonic effect that would cause corrosion on the other end of a good 20' long coax cable from where it was exposed to the weather? Even after re-stripping the cable inches from the corroded fitting, the stinger (the wire down the middle) still had a patina on it that I filed a bit to make it shiny. On both fittings.
  • RoyB wrote:
    We ham radio guys find this all the time when we a have RG cable feeding the center of a dipole antenna hanging way up in the air with pour tape seal... Water runs down the inside between the center conductor portion and the cable braid... Once the copper get hits with water and heat then it turns a good green color...
    Got to make sure the RG connectors have rubber boots and sealed up to prevent water from seeping inside them...
    Roy Ken
    I did that...with every connection up there except this one! LOL!
  • Using di-electric grease inside all outside coax connections will almost completely eliminate these kinds of issues.
  • RoyB's avatar
    RoyB
    Explorer II
    Roy Ken
  • dissimilar metals.
    and moisture will travel inside of cabling
    and could have started before you purchased it.
    factory, warehouse, dealer...
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Oct 16, 2025
