Jay_Pat's avatar
Jay_Pat
Setting up 211K and Eastern Arc 1000.4 Antenna
For an upcoming trip to the northeast and down the east coast a ways, I'm attempting to setup Dish Satellite (DS). It was suggested here on rv.net to use the eastern arc.
I have purchased the 211K, 1000.4 antenna, tv4rv tripod and 50' of rg6 coax. The 211 and antenna (antenna was assembled with 1 coax coming out of the arm) were purchased locally here in Round Rock, TX.
The guy at the store setup the 211 on a western arc antenna.
At home, I set up everything in the rv using existing satellite connection. Found a eastern signal, program guide downloaded and then dropped signal. After that, I could not get a signal.
I repositioned the antenna, directly wired the coax between the 211 and antenna. Got another 5 bar signal, downloaded programing, dropped signal.
Also, I took off the LNB to see which connector the coax was connected to. It was connected to #3 connector (third connector from the left).
Any suggestions?
Thanks!
Pat
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jun 18, 2025
