whjco
Feb 01, 2020Explorer
Rover_Bill wrote:
FYI - I have a Garmin RV660LMT with a Garmin BC30 camera mounted in my ultra light TT (fiberglass shell on aluminum frame). Garmin says that setup is good for up to 45 ft. separation between camera transmitter and GPS. My RV660 picks up the BC30 signal atleast 200 ft away when parked at the CG.
To fix your map download problem on your RV760, I recommend you download and install a fresh copy of Garmin Express on your PC. That installation should correct any bad connectivity settings on your PC.
Garmin RV760 requires a BC20 camera (now obsolete) NOT the newer BC30 model. The wireless receiver on the BC20 model is located in the special mounting plate on the back of the RV760 GPS. The receiver for the BC30 is located in the power cable. Without that special mounting plate receiver (which is part of the BC20 kit), I doubt that a BC30 camera will work with your RV760. This LINK may help explain the differences between Garmin cameras.
I'd add the recommendation that you completely uninstall Garmin Express before you install the newly downloaded copy.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
