Dave_H_M's avatar
Dave_H_M
Explorer II
Apr 25, 2015
Strange window on the comuter screen
Out of the clear blue I am getting a small window on the screen with print inside as follows:
There is no disk in the drive. Please insert a disk into drive \Device\Harddisk 2\DR2
That critter is hard to get rid of. I do have an external hard drive hooked to the computer but has been there for years.
Your thoughts on getting rid of this issue would be appreciated.
  • no.. they have they too be used at the same time
    i'm forced to limit my use to TWO devices on the available usb ports
    there fore i have to choose to use two external hard drives out of four available
    or ONE HD and the DVD drive
    NO internal cd/dvd
    if i am processing a video from one drive and storing the finished product on another drive, it takes BOTH of the available ports
    then to burn or transfer that file i have to unplug the first drive and connect the dvd burner
    none of that has anything to do OP problem
    Except that PC sometimes gives me the same message
    when i get MY laptop back , all will be well
  • MrWizard wrote:
    I have a USB hub, it is not practical for my uses
    Processing and transferring video information between drives sharing the same port on the laptop, by sharing that port using a hub
    Not practical..slows down too much
    Switching is faster?
  • I have a USB hub, it is not practical for my uses
  • i have seen that window
    on this (less than 4 weeks old) Dell LOANER
    when some process expected my external DVD burner to have a disc inside
    this laptop has NO cd/dvd drive
    and i have to use an external
    i only load it, when i'm going to burn a disc
    but occasionally this thing thinks there is supposed to media inside
    i think its a bug in windows 8.1
    yeah yeah .. i know somebody is going to NOT agree with me
    never had this problem on my win8 Lenovo
    only on this win8.1 DELL
    this thing is also short on USB ports
    and i have too swap around between my external Hard Drives
    and i have trouble disconnecting
    it will tell me can not do that because the drive is in use
    when i closed all windows and programs, that been accessing that drive
    whether it is the Dell hardware , BIOS or the win8.1
    it is still a Royal Pain
    and NO.. i am NOT going to in depth research diagnostic and meddeling
    this thing is NOT mine, it is a LOANER from Frys and going back in the next 2~4 weeks, when mine comes back from repair
  • This could indicate an imminent failure of one of your hard drives or disc controllers. Could also be a loose or defective cable. Check you connections.
    You may also want to run error checking and disc utilities to determine the status of the affected drive.
  • Did you run or access anything from the external? It sounds like something is trying to find it or it is conflicting with another drive.
    It could also be that you changed (by removing and reattaching) the drive letter of the external, which something was accessing.
    Reboot with external disconnected then reconnect after you log in.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 27, 2025
