silvercorvette's avatar
Oct 16, 2015
To drill or not drill installing back up camera
(I hate putting holes in my RV)
I upgraded my Garmin and added a BC 20 back up camera. I hate drilling holes in my 5th wheel because I am not sure I may damage something. I will mounting the camera on the license plate. I am going over to the storage yard today to see how the license plate bracket is mounted and wired
Option one, try to use the license plate hole and wiring and only drill one small hole in the interior.
Option two popped into my mind last night. Not drill any holes and run the wire thru the slide opening. The downside will be having the wire flap in the breeze. Maybe I can secure the wire by putting a dab of silicone sealer a few inches apart.
I do not know if this matters, it is being installed in a 33 foot Alumascape Holiday Rambler 5th wheel
  • tenbear wrote:
    I mounted mine inside the rear window. Didn't have to drill any holes.
    Of course, I don't know if you have a rear window.
    That was my first thought but I think it is switched between GPS and camera by the reverse light. I am going to drive over today and see if I am reading the instructions correctly. I am confused as to the back up light, maybe it can be activated by the trucks back up light?
  • Mount it to the license plate bracket and wire it to the license plate light for power. This is the beauty of a wireless camera. No need to run wires anywhere. No holes to drill into the camper.
  • I mounted mine inside the rear window. Didn't have to drill any holes.
  • Since you are going to mount it at the license plate there should be a light nearby. Is it possible to use the hole for the wire that the plate wire is using? JMO
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
