Bill_Satellite
May 21, 2016Explorer II
The 99 and 103 numbers are very bad but 101 is very good. Have you set your receiver to show both SD and HD channels to see if the missing channels are available in SD? If not, give it a try and I suspect you will find that they show up. As mentioned above you also need to set the receiver to the correct antenna type. The new Trav'ler with built in SWM uses antenna type 17 and SWM. The older non-SWM or a non-SWM converted to SWM 8 will use that or a different SWM setup (antenna type 8 if IIRC).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 01, 2026
