Bill_Satellite
May 21, 2016Explorer II
Either your antenna is partially blocked by a pole or tree or you have an issue with the antenna itself. The LNB could have gone bad but you are getting just about NO service from the 99 and 103 LNB's. The 101 LNB is fine and the signal right about where it should be. That's why you are getting SD but not HD. HD is broadcast on the 99 and 103 satellites while SD comes from 101.
Ignore numbers from 99(s) and 103(s) as these are spot beamed transponders and rarely show any signal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 01, 2026
