Bill_Satellite
May 21, 2016Explorer II
Belgique wrote:
I'm in the Tucson desert so no blockage. No electrical storms in Mexico but a whole lot of shake rattle and roll. Where does one get an LNB for Travler...is it a Winegard thing? What should I ask for?
Thanks so much!
This is what I have now: DIRECTV SlimLine 5 LNB Ka/Ku Slim Line LNB for Satellite Dish (SL5), Brand: DIRECTV Slim Line P\N: SL5 UPC: 752902100882
RV.Net won't let me post link to Solid SIgnal site
That is what you would replace it with. It is not a Winegard part, it is a DirecTV part.
So, if that is the LNB and you are not using SWM then the eariler setups are not correct and you must also be using a B-Band converter to get HD. You need the Slimline 5 antenna selection and Multi-switch as the switch type. That is likely where you were when you started. 110 and 119 will show up but there is nothing on 110 and almost nothing on 119 so simply ignore any information on those transponders. This also assumes that you did not add the SWM8 kit to convert your older Trav'ler to SWM.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 01, 2026
