Bill_Satellite
May 21, 2016Explorer II
You must use the same LNB that came with your Trav'ler if you need to replace it. The antenna uses 101, 110 and 119 to set the antenna properly so replacing it with anything else would be a mistake. You also cannot update to the SL5 SWM setup so just get a replacement exactly like the one you have.
My "WAG" is that it's something else but that's as good a place to start as any assuming you have done the "calibrate EL" routine and it was successful.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 01, 2026
