Dlesron's avatar
Dlesron
Tv cable routing
The tv in the bedroom will no longer recieve the air tv stations. The tv in the living area does, and the booster is on. I have replaced the coax from the wall to the tv, and did not change. Took the plate off the wall, has two coax cables into a splitter of some kind. Took them off and then put back on.
Unable to find a wiring schematic to determine how the two tvs are wired from the antenna.
Any ideas? The tv connected fine and then lost connection.
  • Ended up being the tv. Bought new one, problem fixed
  • Don't think it was over tighted, don't have a picture of the splitter, has one input and two outputs. The trailer and tv are 3 years old.
    Am going to get a new splitter and see if that works.
    Thanks for everyone's reply
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    I would run some voltage off a battery through the coax to the bedroom first to make sure the line is good, then proceed from there.
  • Do you have a picture of the wall plate splitter? It is likely a loop through system and that splitter has failed. It is probably losing too many dbs to give you a picture.
    I am a cable guy and I see them in older houses but they no longer work in most cases.
  • Not much of a chance that any of the cabling has gone bad with maybe one exception. Have you any problems with mice ?
    Aside from that, there may be a problem with either the "splitter" as you described or the tv, itself. Try taking the bedroom tv into the living room & connecting it, & see what happens. If it gets reception there, then you've narrowed the problem back to the splitter or cabling.
    How old is the RV & the tv, in the bedroom ?
  • you didn't over tighten the cable to the TV did you. they aren't made to take much and it may have snapped the input connection.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
