jimj's avatar
jimj
Upgrade to Geni
I have the non HD dome on the MH and want to know what I will have to do to get a Direct TV Geni from the house to work in the MH. I know it will not be HD. I have been swapping the older DVR but want to upgrade the house to the Geni setup.
How much?
Thanks
JimJ
  • They will use a SWM3 LNB built into the antenna they install and not a SWM8 switch.
  • I called Directv today and wanted to swap out a 24 for another (second) 34 or a new 44. They said NO WAY, only one Genie per account. Not sure why but suspect it is due to shortage and not technical. I wanted to leave my 34 at home and take another Genie with me. From what I read, even if I ordered and paid for myself, Directv would not allow activation.
  • Thanks for the great info from everyone.
    Bill Adams
    I have ordered the Geni setup for the house, instal next Thurs. I would like to know what type system they use for a new instal, the Swm8 switch or the Swm LNB to the receiver? I would like to be able to receive the OTA TV in the house in case the sat goes out or Direct follows cable and stops carrying some channels. I think the Swm switch has a port for the OTA antenna and that would be the same setup that I will use for the MH.
    Thanks
    JimJ
  • OP, make sure your understand the dome with a SWM8 will only give you SD. If you want HD, it's the Trav'ler SK-SWM on the roof or a Slimeline on the ground. For ground mounting, a TV4RV.com HD combo Kit is great. The Trav'ler is automatic while ground-mounting requires manually aiming the dish. Some find that daunting while others find it a snap. For me it's normally a kind of fun fifteen minutes. Tools ranging from nothing to several hundred dollars are available to get it done. I think the minimum required is a compass and a level. Some just use the box by trial and error.
  • I use an old slimline dish on a tripod. You do need the swm lnb, a splitter, and a power inserter. That is the only way, other than purchase a $1600.00 traveler, to get HD. I used tv4rv.com for the tripod, meter, and various items necessary to level and secure the tripod.
  • Pretty sure the HR34 is SWM only so you'll need a Winegard SK-SWM (or SK-3005 with a SWM conversion) roof mount or a Slimeline dish on a tripod on the ground. The dome might do SD only with a SWM conversion but that I don't know much about.
    Maybe bill.winegard will pop as he is in the business.
    You might also search winegard swm and come up with some instructional PDF's.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
