was_butnotnow's avatar
Feb 29, 2016
Upgraded to Win 10
Well I bit the bullet and upgraded my Win 7 desktop to Win 10
I did our laptop win 8 and all went well so next was to see if I wanted to do the desktop. I have a couple of old programs and was worried if they would work under the new OS. I have an old Netscape Composer 4.79 which I love and use it to build my web sites. It wouldn't run on the laptop under Win 10 but I also have Netscape 7.2 that does. Also I now use Mozilla Thunderbird for email so knew it would be OK in Win 10. But I used to use Eudora email and wanted to make sure I could access the old email files.
Win 10 said these old programs would not run but after upgrading ALL my old 32bit programs run just fine.
I am very impressed how all old program settings transferred over.
And both my old Composer 4.79 and Eudora also run great. The thing is these old programs run ok since they were already installed on the old OS. But if I would want to do a new install of them then they wont run.
Another reason I wanted to upgrade to Win 10..., I had so many Win 7 system updates on my old OS some updated and some didn't. Now all that is gone and a fresh start with a new OS. Microsoft got this one right. Oh and when traveling with limited bandwidth there is a option to tell it you are on a metered ISP so updates don't blow your usage.
Go to settings...Network and Internet...Advanced settings...Metered connection... set as metered connection. Also go to settings... updates and security...advanced options... Choose how updates are installed...pick Notify to schedule restart... You'll be asked to schedule a restart to finish installing updates. Updates won't download over a metered connection (where charges may apply).
  • Can you run Visacalc on Win10? I don't want to upgrade.
  • I upgraded my Samsung Laptop from 8.1 to W10 last week. The only issue I have that I can't solve is the screen brightness will not change. Fortunately it is on bright so I'm not stuck. Nothing works and Samsung doesn't have an answer yet. I hope yet is correct word.
  • bwanshoom wrote:
    Why do you still need to use that?
    I assume:
    He paid for it.
    It works for him to do what he wants or needs.
    Why should he be FORCED to change ????
    Hint: He shouldn't be.
  • mileshuff wrote:
    Could not use Win 10 myself. Too many older programs that won't run. Need to use MS Visual Studio 6 which barely runs under Win 7/8. Might be able to setup a virtual box on Win 10 and load XP on it. Very costly to rewrite custom software each time MS changes OS's. For those running off the shelf common software its not as big of a problem.
    VS 6? Wow, that's nearly 20 years old. Why do you still need to use that?
    Your opinion. Glad it worked for you.
    Note for those still on 7:
    About the time that Microsoft installed it's "nag-ware" for 10 on my machine without my permission, the automatic notification of pending updates also quit working. Same thing on my wife's computer. By the time I realized this it had been off for about 4 months and there were over 25 updates available.
    IF YOU ARE STAYING ON AN EARLIER VERSION, BE SURE TO CHECK FOR PENDING UPDATES.
  • I miss Eudora- best POP Email program, bar none. If it was still around, it would *almost* make it worth it to use Windows again.
  • I had an interesting experience with W10 yesterday. I've been using W10 since before it was released so I (thought I) know it pretty well.
    A neighbour was having trouble downloading videos from his camera and uploading to Facebook. I said I'd help. The W10 I know is an upgrade from W7. I use W10 pretty much the way I used W7 with all the same applications. The neighbour's PC obviously had W10 factory-installed and he was using the full app experience. Turns out I didn't know how to do anything, even getting from one app to another.
    After 30 minutes learning curve, I was able to get the videos out of the camera but I just wasn't able to figure out how to upload to FB using their app. Turns out the app doesn't have an "upload video function" like the website - you have to have the video in folder "camera roll" and share it to FB.
    I'm going to have to requalify my comments about W10 - I like W10(7)!
  • Could not use Win 10 myself. Too many older programs that won't run. Need to use MS Visual Studio 6 which barely runs under Win 7/8. Might be able to setup a virtual box on Win 10 and load XP on it. Very costly to rewrite custom software each time MS changes OS's. For those running off the shelf common software its not as big of a problem.
  • Made the switch from 7 to 10 (desk top) a couple of months ago.
    Flawless transition and flawless performance.
    W10 has lots of flexibility, and control. Take some time to poke around the settings.
  • So far win 10 has worked well for us with a lot of old programs. Even Snagit 10 came over from the XP machine. A little harder to get rid of the white title bars and hard to see scroll bars. A few tweaks and that was fixed. And the final tweak was getting windows updates back into control panel. Now all is sweet. Probable means it will crash tomorrow?????
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
