GordonThree wrote:
DOTLDaddy wrote:
I suspect this will get a lot of "maybe" answers, but what the heck. Maybe one of you have tried this.
My 2013 Silverado has the bare bones AM/FM/CD/MP3 radio. No usb input, but it does have the 3.5mm "aux input" receptacle for an ipod or the like.
I know there are usb to 3.5mm plug adapters available, but would my radio recognize mp3 files on a usb stick if I stuck it into the radio using such an adapter??? :@
A lot of nay sayers out there, not sure why??
I have a USB to 3.5mm adapter, and it worked just fine in my older radio. It had a tiny screen, some buttons, a USB port, a 3.5mm port with a short cable and goes in the lighter socket. It also has an SD card slot.
All it was really is a tiny MP3 player - the car radio itself did nothing but playback the music.
If you want more control, capacity, etc, look at a refurb IPOD - buy it from Apple so you don't get scam'd.
A "PLAYER" is not what the OP was asking about.
OP wanted to know if there was a USB to3.5mm ADAPTER that would allow the indash radio play the music files.
The answer of course is no, you can not DIRECTLY play MP3 files DIGITALLY through the 3.5 mm connection which is for ANALOG audio only.
The OP WILL need to purchase a MP3 player then connect the headphone output of the player to the 3.5 mm input jack of the indash unit.
The OP CAN use ANY MP3 player that either has internal memory OR can accept SD/Micro SD or USB flash memory.
The downside is the OP can not "control" the songs on player from the indash radio AND the player will need to run off internal batteries or some can accept a USB 5V charger while playing.
HERE is a very basic MP3 player (no screen), runs off one single AAA battery for $2.85 that accepts micro SD cards although they do have a $7.00 flat rate shipping charge
The same place also has the same player for $7.95 which includes a 2 gig micro SD card and a micro SD card reader to USB (use the adapter to plug card into your PC to load the card).
HERE 2 gig will give you about 20hrs of MP3 music at 128 kb data rate.
If OP wants to play directly from a USB drive then they will need to buy a new indash unit which has a USB port.
There are MP3 players that plug into the cig lighter jack that accept USB flash memory but they tend to have a FM transmitter and some may have a analog audio output which could be used to feed the indash unit. Do be aware that those tend to forget the last song played and you will have to mess around with them each time you start the engine. One brand to skip is Pyle, that brand name is garbage..
