happycamper002
Jun 22, 2017Explorer
MEXICOWANDERER wrote:
Good info. All three speakers use 3.5mm stereo plugs. Two JBL's have plugs for 120 volt receptacles. The single unit measures about 3" x 6" x 2" and (I guess) uses the USB connector for power. Meaning the red speaker has both a USB connection and a 3.5 mm jack.
Three 3.5mm plugs and one laptop jack. The main question is whether the laptop (headphone) amp could handle both 3.5mm JBL speakers. The 120vac 2-prong plug has to be for the speaker amplifiers.
So then the laptop can run the 3.5 mm jack and the USB simultaneously?
Since you are using the audio output from the 3.5mm,(which is what you're doing anyway) you won't need the USB to provide power to these huge speakers. The speakers are amplified with their own power from their 120 volt cord. So just forget the USB.
I would then need a "Y" or the jack. And suitable extensions for everything. (?)
Absolutely . . . with stuff that I mentioned, you will need to make some kind of distribution strip or a customized connection points with matching 3.5mm ports (or RCA connectors) so you can plug in your speakers.
This would also be the connection point to provide power to each individual speakers.
I sense that your dilemma is what the USB's role would play after all is said and done. You wouldn't need the USB-supplied power, so just put a plug or tape over it. The power coming out of it is puny to what you are trying to accomplish.
Ha! I found a 10" Polk amplified subwoofer that could replace the red box speaker. Guesswork tells me connection of the laptop to the Polk subwoofer also needs to be confirmed. How forgiving are subwoofer amp inputs?
The sub-woofer is for the most part a bonus. It is mostly noticeable if you a have a home theater amplifier which has a 4-channel outputs.
Left channel, right channel, center channel and rear channel.
The sub-woofer is usually tied in to the left channel. It doesn't modulate as much as the right channel. In some 5.1 systems, the sub-woofer has a separate channel.
This is a traveling circus via toad. So the subwoofer is a major space consumer.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
