wa8yxm
Dec 13, 2014Explorer III
With the older dishes when you first hooked up you went MENU 6-1-1 as I recall and that took you to antenna pointing.. At this point you may or may not be "Authorised" it makes no differnece,, Now using a battery operated portable TV at the antenna site (or a 120 volt one for that matter) aim your dish (Enter zip code first).
once you have got the dish aimed you go to CHECK DISH, this is where it checks for authorization.
On some of the newer ones you have to wait for the thing to stop trying to aim a Tailgater, once it gets to that step you hit the "*" button, then I think it takes you to Menu 6 1 1, if not you have to go there.
From there it is the same procedure.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
