- jcpainterExplorerWhen you tether from your phone . . . unless that's the only thing you are using the phone for . . . it's impossible to know how much of your data usage is coming from the "hot spot/tether" bucket and how much was other usage.
Only the "hot spot/tether" data usage counts toward the 10GB. Remember that "hot spot" refers to both an independent physical hotspot (like a jetpack) or when the phone's hot spot feature is being used by another device.
Since Verizon doesn't separate the usage on a phone, it's hard to know how much data usage was applied to each "bucket". - 2001400exExplorer
prstlk wrote:
2001400ex wrote:
prstlk wrote:
I switched our plan about a month ago and I'm not really happy with it. My computer doesn't like 3g service. The internet continually goes off and then I get a DNS error. I have to restart my computer, sometimes 2 and 3 times and I have to turn my jetpack off and back on at least 1 time as well.
I have never tried to stream anything on my computer or tv - can't imagine how long it would take at 3g service!
Things like short movies shared on Facebook are slow to buffer and opening more than 1 or 2 tabs makes everything really slow. And, heaven forbid my husband get on the internet on his tablet while I'm on the computer - it's a battle to see who can get their pages opened first.
I'm thinking about calling and switching back - which I was told I could do and I made sure it was noted in my records. I had the 30GB plan before and only really had 1 or 2 close times where we went over by 1GB for the month.
I also hate how Verizon tells you it's all unlimited but it really is a limited plan - they slow it down and still control what you can and cannot do with your internet. It's unlimited but really slow!
Any other plans out there that allow you to have 4g lte on an unlimited basis?
I live in the same area as you and used 35gb on my line alone last month, with about 25gb from WiFi tethering to another device. I haven't noticed any slow down at all. How much are you using a month before you start seeing it slow down?
It slowed down pretty much the same minute I hit the 10GB on the jet pack. They sent me notification of my hitting that limit and the issues started that same afternoon.
Ok, that's the difference probably, I'm not using a jet pack. I'm just tethering from my phone.
Also add another person mentioned, I had one of those $5 a month jet packs last year and I was able to stream Netflix all day long at the 3G speeds. So when Verizon throttles now, maybe they are restricting it too much. - Dutch_12078Explorer IIII think the biggest failing of the VZW limited/unlimited plan is that when they drop you down to 3G, it isn't even normal 3G speeds, it's a speed (600Kbps?) that's at the lower end of 3G. Heck, my gray market VZW $5/mo unlimited 3G plan routinely gets speeds of 1.5-2.5 Mbps down/0.75-1 Mbps up. I've streamed full length Amazon Prime movies with it with zero buffering on several occasions.
- prstlkExplorer
Bill.Satellite wrote:
So the limit with a jet pack is 10GB and it sounds like you already knew that. If you are in a area with a lot of people your service is going to suffer. This really should not be a surprise. Verizon only promises that you will still have service but there is no service level promised.
Amen to that - that's their usual MO. - Bill_SatelliteExplorer IISo the limit with a jet pack is 10GB and it sounds like you already knew that. If you are in a area with a lot of people your service is going to suffer. This really should not be a surprise. Verizon only promises that you will still have service but there is no service level promised.
- prstlkExplorer
It slowed down pretty much the same minute I hit the 10GB on the jet pack. They sent me notification of my hitting that limit and the issues started that same afternoon. - 2001400exExplorer
I live in the same area as you and used 35gb on my line alone last month, with about 25gb from WiFi tethering to another device. I haven't noticed any slow down at all. How much are you using a month before you start seeing it slow down? - prstlkExplorerI switched our plan about a month ago and I'm not really happy with it. My computer doesn't like 3g service. The internet continually goes off and then I get a DNS error. I have to restart my computer, sometimes 2 and 3 times and I have to turn my jetpack off and back on at least 1 time as well.
Any other plans out there that allow you to have 4g lte on an unlimited basis? - 2001400exExplorerI used 23gb using my phone as a hot spot this last weekend. Didn't notice and throttling, I used Netflix the entire time without any issue.
- jhilleyExplorer
TheSidwells wrote:
No issues for me except I use to much data but then it all work related. I average 30gb a month and since switching to unlimited it saves me $$ and no change in performance that I noticed so far. I did call verizon and asked about the limits and was told if I live in a metro area and reach 28gb the bandwidth could be throttled back depending on demand but that is unlikely.
If you can hold off a month or 2 5G is coming out. Its worth the wait if time permits.
It will be about 2 years before 5G is available
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
