boston_blacky's avatar
Jul 08, 2015
what to do with (atieclxx.exe) - how to remove it ? ?
Greetings/Bonjour;
I've had a slow p.c. with a less the normal line speed over the past few days. From what I can say thus far - it may be a program called atieclxx.exe! Where it came from and what I can do to remove it - completely is a "unknown" at this point. If you've experienced this - and can lead my in the right direction, it would be much appreciated.
Thanks in advance.
  • If your motherboard has no ati onboard graphics and no ati graphics card but still have it running, then it could have a virus. Also it should be located in the Windows/System32 folder. If it is located somewhere else it could be a harmful program.
    Just depends.
  • I would open up the task manager and check processes first to see if any are using more than usual cpu, then memory to see if I'm running low on memory. You can check the memory by process if that looks like the problem.
  • My first approach would be Malwarebytes
    My second approach would be a "system restore"
    To a date before the problem
    What browser are you using ?
    And how long have you had the problem?
    What version of Windows?
  • Download and install Malwarebytes (free). It does a very good job of finding and getting rid of junk.
    Also... go to your control panel, and look at the list of installed programs. DON'T delete anything that you don't know what it is. Google it first. If it's garbage, un-install it.
  • atieclxx.exe runs on my computer too, for my graphics card. No infections on my system so I doubt it is that program.
  • If you type the program name in google it tells you what it is and how to get rid of it
  • A simple google search told me it it a video card driver. Most likely you need it. You can see if there is a driver update that might run better.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
