DD716TED's avatar
DD716TED
Windows 11 ..headaches..
I have a new Dell All-in-one Windows 11 computer.. My question is sound.. I want to be able to used the audio out jack for the stereo/speakers on patio and at the same time listen to the computers speakers in my shop... I can get the audio out jack to supply output to the stereo but am unable to listen to computers built in speakers at same time.. and when I unplug the audio out jack, the computers internal speakers work.. I want to use both at same time but haven't figured out how to do it..Utube has been of no help...Anyone else experience or solve this Win 11 hurdle?
  • This is not a Win 11 issue, but a hardware issue. It's the way things work. You can get a secondary as suggested, or an Amazon Echo. You can't Bluetooth two separate devices to one computer. Even Bluetooth operates this way.
  • Don't know anything about all in ones, but the audio driver control panel is where you probably need to be. Realtek is very common on PCs and Notebooks
    This a very "old fashioned" thing. Sometimes there is actually switch built into the audio output jack. When you plug in the external speakers it turns off in internal ones. Because this is mechanical, Windows has no control.
    Buying wireless speakers would help because Windows can control them. Bluetooth has a limited distance.
  • second the notion of bluetooth speakers. or use two sets of wired speakers with an audio splitter coming out of the speaker jack into the splitter and then out from there to each set of speakers. personally i think the BT speakers are your best bet.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
