rrupert wrote:
Ok, all you Windows XP owners, including me, Microsoft will no longer be supporting twelve year old XP as of April 8, 2014. What this means is that XP will no longer get any updates. They will continue for a time to support security software. They suggest that you upgrade to a new computer with Windows 8.1, or upgrade your system to Windows 8.1 if your computer is capable of handling it. You may want to do all available XP upgrades prior to April 8. After they stop updating security software you are advised to not access the internet with your XP machines. That means you will not want to browse or email via XP. You can continue to use XP for your applications that don't require internet access.
The end of Windows XP support
:R
Yet another doom and gloom demise of your XP post because it didn't get anymore highly unlikely security "fixes" which tend to break your XP posts...
rrupert I hate to burst your news bubble, but that is very old news and not to mention subject to daily change...
Additionally there are MILLIONS of PCs using XP and will continue to use XP out there which are highly entrenched and firmly not changing in MANY businesses. With nearly ALL of those CONNECTED to the Internet.
Why?
Simply put, there are many companies which use multiple systems and softwares which either are not readily adaptable or have been found to not play well with the changes made with Win 7 or even W8.
It also takes considerable manpower to install and test all of these systems to ensure nothing gets broken along the way.
Many companies also DO NOT allow any of their PCs to directly access MS Update servers. Instead the IT department SCREENS EACH UPDATE RELEASE and tests it before rolling out the update to their PCs.
The IT departments also will not pass all updates to their PCs, basically only allowing HIGH PRIORITY MAJOR security risk patches.
If you were smart you would take a cue from this, set your Update to ALERT you to updates but not install them automatically.
The reason for this?
Simply put, sometimes the patches are not ready for prime time and can cause major headaches for you if you blindly accept all.
For instance, Win7 had a major blunder concerning .net 3.51 security patch. The update continually FAILS causing your PC to continually attempt to install the failed update. Blindly allowing all updates without at least reading up on them WILL one day bite you in the behind..
I for one do not blindly install all updates...
