tarnold's avatar
tarnold
Winegard mission
Been pushing a lot of buttons, not getting anywhere. Is the subject compatible with a direct D12-100? The dip switches are set for direct. Any thing “extra” needed?
  • if you're connecting the antenna to the receiver using the coach's connector in an outside compartment try running the coax directly to the receiver thru a window or door and see if that helps.
  • Verify that you have power to the antenna.
    Verify that the coaxial cable goes directly from receiver to the dish without any devices.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 01, 2025
