Ropdoc's avatar
Ropdoc
winegard stationary roadtrip minimax
Hello all,
I inherited a Winegard stationary roadtrip minimax dish. the power leads were cut but the plug is still on the unit.
Is there a way to test the unit to see if it still works and can it be used for internet. Also I am trying to find info on the power cord. Can I cut an extension cord and connect the plug to make the power cord. I would like to be able to set it on a table in the field not mount on my 5th wheel.
Thank you,
Dave
  • Ozlander wrote:
    It's yours, you can do anything you want with it.
    but how do I check if it works? I do not have cable yet. Before I get that I want to make sure the satelite works. :h
  • If I plug it into a 12v power source does it go thru a boot sequence so I can see if it works or not.?
  • Ok, thank you. I will look into the cost of cable then. We get it for free at the park. So not sure why pay for it too.
  • No, that antenna can never be used for internet. The LNB is wrong and there is no transmitter of any kind. It is a receive only antenna and only useable with DirecTV, Dish or the Canadian Bell Express Vu (in Canada only).
  • lryrob9301 wrote:
    First of all the Winegard MiniMax is not for internet it is for satellite TV.
    I was hoping to find someone that asked why not and did it.
    lryrob9301 wrote:
    Second it's 12VDC powered not 120VAC.
    now I know to make and extension cord for 12 volt not 120. Cool.
  • First of all the Winegard MiniMax is not for internet it is for satellite TV.
