harley-dave's avatar
harley-dave
Explorer II
Jun 13, 2017
Winegard Travel'r trouble
Good morning all.. We're having trouble with our Travel'r and Dish network setup. I noticed the display shows all 3 sats after alignment (110, 119, 129) but the 129 sat doesn't have an asterisk after it. Whats it trying to tell me? Can't find it in the manual, all it says is it should have one! Anyway, occasionally when turning the receiver/TV on it shows a lost signal message.. I tightened the LNB's on the arm since they were a little loose and then stowed the antenna and let it re-align and it still does it. Any ideas? Thanks in advance for any ideas.
Dave
  • I'm not a Dish guy so have no idea where programming is, but the same thing happens in DirecTv land on 110 that is now used only for programming into Puerto Rico. The last few years they have been fiddling with it and depending where we are, even within a 300mile radius, 110 may or may not lock.
  • harley-dave wrote:
    Thanks rk911, I was hoping to avoid that.
    Dave
    I hear ya. I have a number that allegedly goes to the advanced tech support. you might give that a try.
    1-800-894-9131
    Dave
    that means it's not locked onto that sat. result means you'll likely not get much if any HD programming and locals may be SD also. if you have a totally clear view of the sky then a call to DISH tech support is in order.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 18, 2025
