Ron_Gratz's avatar
Ron_Gratz
Winegard Trav'ler DirecTV Slimline
This satellite receiver antenna -- Trav'ler DirecTV Slimline -- was installed on the roof of my MH about a year ago.
After moving to a new location, the system routinely takes several (10-15 minutes) to find and lock onto satellites 101W, 99W, and 103W.
It would indicate identifying 101W fairly early in the search, but then would disregard having found 101W and would continue to "search".
The "search" process then mainly involved raising to a very high elevation, rotating 360 degrees of azimuth, lowering to a very low elevation, rotating 360 degrees, and continuing these actions without any apparent search logic.
After going up, around, down, and around again and again for maybe another 15 minutes, the system would find and lock onto 101W and the other two satellites -- seemingly more by accident than by design.
A week ago, the system was unable to find the satellites after "searching" for one hour.
There was absolutely no line-of-sight obstruction.
I called Winegard technical help, and was led through the process of stowing the dish, disconnecting and reconnecting the control cable at the control box, and then disconnecting and reconnecting the control cable in the access box at the base of the dish.
The search mode was then activated and the satellites were acquired within three minutes.
Two days later, after moving to a new location 90 miles to the NNW, it took 36 minutes to lock onto the satellites.
The system identified 101W after 21 minutes, but then continued to "search" (high, fully around, low, fully around, etc., etc.).
After 12 more minutes of "searching", satellite 119W was identified.
After 3 more minutes, 101W and the other two satellites were found.
Has anyone else using this product experienced such long lock-on times on a routine basis?
Does anyone have any idea why my system takes so long?
Thanks for your help,
Ron
  • Its getting ready to fail! Im on my second one. Winegard, me, and finally a servicing dealer were after several thousand dollars in parts, shipping, and troubleshooting were unable to make it work. Winegard finally gave up and installed a new one. This one has been fine.
    But you might start with ensuring all connections are clean and tight. If that does not do it, replace the coax from the dish to the receiver. Failing that, try a new LNB. Also be sure nothing is loose or bent. A loose LNB arm, can create lots of problems.
