kandkkustomz's avatar
kandkkustomz
Winegard video distribution 12 volt fuse on 04 Monaco
Having trouble with my winegard video distribution selectoron my 2004 Monaco Diplomat. Have no power to it tested 12 volt lead coming into box with multimeter and not getting 12 volts must be a fuse I would guess somewhere but where? Cant find anything in wiring scematic. Someone please help with fuse location.
  • You will be looking for a 12V fuse labeled TV antenna or similar. The power going to the Winegard box is primarily (and in some cases only) there to provide power to the OTA TV antenna. It's normally a 7.5 amp fuse.
  • kandkkustomz wrote:
    Yes I know that houses most of the 12 volt fuses however not sure what one it would be as its not listed n box or wiring schematic. Hoping someone knows specific number it would be. Hate to check all of them one by one.
    Have done that more than once. With a good circuit check light, only takes about 10 minutes....
  • Yes I know that houses most of the 12 volt fuses however not sure what one it would be as its not listed n box or wiring schematic. Hoping someone knows specific number it would be. Hate to check all of them one by one.
  • Have you looked in the exterior electrical control center under the drivers position? That is where Monaco put 99% of the 12v systems power fuses.
