Bill_Satellite
Jun 21, 2013Explorer II
There should be a coax output connection on the face of the plate which you run to the TV coax input. You can verify that the 12V power supply/booster is working and wired correctly by going on the roof and removing the coax from the head of the antenna. Using a voltage meter you must find 12V+ in the coax itself.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
