Dutch_12078
Mar 21, 2017Explorer III
The Mobley will work fine in your home with an available 120VAC power adapter. To connect it to your home network, your router needs be one of the makes/models with a "WiFi as WAN" feature that will let it connect to the Mobley's Wifi. With that connection, if you connect your other devices to the router instead of the Mobley, there will be no need for anything to switch networks as you move around the house and out of range of the Mobley. I use a Cradlepoint MBR95 for my "WiFi as WAN" router, but that model has been superseded by the MBR1200 as I recall. PEPwave and WiFiRanger are two other popular brands for "WiFi as WAN" routers. My Mobley just arrived at my mail forwarders, so I haven't had a chance to play with one yet, but I'll be setting it up for both 120-volt and 12-volt portable operation with suitable adapters. I also have AT&T's 250GB/mo $60 plan with unlimited phone service, but that unit is a bit bulky for portable use. The Mobley and the $20 unlimited plan will make a nice addition to my connectivity and be almost as portable as a standalone hotspot.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
