AMOS33
Aug 02, 2017Explorer
Bill.Satellite wrote:
A load balancing router will not increase speeds. It works by trying to keep the speeds of each from dropping due to network congestion. It would send multiple web requests using which ever connection appears to be less used. I have played with them in the past and was never impressed. I also worked with a company called Mushroom Networks that allowed you to plug multiple cell cards into 1 device and it actually DID increase speeds as it could aggregate the signals but it was pricy and if 1 service dropped off 4G then none would use the 4G service. Things are likely better (and more expensive) these days.
Reckon I am just too curious sir, so I purchased a load balancing router and am in the process of setting it up. It has 1 Wan port and 3 Wan/Lan ports and 1 Lan port. Just now I have my Wan port plugged into my Nano Powerline Adapter which ends at my DSL router about 200 feet from my RV. I am trying now to figure the best way to connect my ZTE Mobley to one of the available Wan/Lan ports to see if I can get any good results.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
