pianotuna wrote:
Hi mlts22,
Does the macerator work to pump into a toilet in a home? I.E. up hill?
That is what I use it for. I bought it because the dump tank I was using was about a foot higher than the pump drains on my TT. So, I had three choices: Bury the dump tank, raise my TT to precarious heights, or just use a macerator pump. I used the last option, and it worked very well, both pumping uphill and pumping 100 feet away via a 7/8" hose. I think it can pump up to six feet uphill as well, so it should be able to be used with a toilet... but the first time you do so, either have two people or make sure you secure the hose going in the commode. That way, when it jerks back due to the water pressure, it continues to dump in the toilet, and not the ground.
