enblethen
Jun 17, 2018Nomad
Does not sound like the step motor. Sounds more like a power issue.
If it operates with engine running or ignition is "run" position, power is not getting to the step. There should be an over ride switch near entrance. It could be in wrong position.
Next check to insure the coach battery disconnect is turned on.
About RV Newbies
