- dodge_guyExplorer IIGet the compressor with the higher CFM rating and a larger tank say at least 10 gallons. I do my "E" rated tires on the Excursion and trailer with a Craftsman 25 gallon 135 psi (I don`t remember the cfm, but it is lower than I would like) and it is just enough. your either going to want a much larger air tank or something with a higher cfm!
- Harvey51ExplorerCompare horsepower if possible. You can get high pressure with very little power but it will be very slow. A half HP is decent. And make sure you can lift/carry it, unless you plan to leave it in one place.
- harley-daveExplorer II
barney bugle wrote:
Thanks guys.im a little confused as I have seen some 150 psi with lower cfm than say a 125psi.any ideas?
the CFM rating normally applies to compressors that are powering tools. However it would effect fill time on large tires somewhat.
Dave - RoyBExplorer IIoops entered in error... did'nt read comment close enough...
Roy Ken - calamusExplorer
The Cfm is cubic feet per minute it is based on the size of the cylinder . Your psi is determined by the pressure switch Which some models you can pop the cap and crank up a bit, but the tank itself is the big factor in the PSI of the compressor, as they are designed to hold only so many PSI safely. - barney_bugleExplorerThanks guys.im a little confused as I have seen some 150 psi with lower cfm than say a 125psi.any ideas?
- harley-daveExplorer IIGood Morning
I would look at a 150 psi compressor or even a 135 psi. Those last 10-15 pounds will be pretty slow with only 15 lbs. difference between tire psi and compressor psi. Can be done though.
Dave - 2oldmanExplorer IIHave you seen these? Compressor 110 search results
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
