stevenicol
Jun 09, 2016Explorer
wa8yxm wrote:
If it is a portable unit... use a pair of dogbones.. (one 30-50 one 50-30) and not only will it work,,, perfectly... but these devices serve multiple functions.
ONE is spike supression (Fast short transint high voltage) and the 50 amp unit (when used on a 30 amp circuit) is far far better at this than the 30 amp unit is.
If it is a hard wired......
You have two legs.. Bridge them,, The current sensors,, Put 'em both on the combined wire.. It will still work just like the above.
This IS NOT A GOOD IDEA on our last outing, there were no 50 amp plugs, only 30; so, I plugged the 30 amp male to 50 amp femail dogbone into the 30 amp plug; the 50 amp Progressive industries surge-protector was plugged into the femail side of the 30 amp to 50 amp dog-bone; our 30 amp trailer cable was plugged into this. It all worked fine for about 4 or 5 hours, then the power went out. One of the dog bones femail plugs were fried to a crisp. We purchased a 30 amp power protector this week: lesson learned.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
