I am thinking about installing a small high intensity reading light above our chairs tapping off of the original lights installed. Can I use eyeball type lights from Home depot or do I have to get ...
Basically you can't make the wiring both 12 volt and 120 volts (or use the same wires). You will need to either buy lights that match the existing ones or run separate wires and separate power source for the new ones.
