- sch911Explorer
2112 wrote:
It is not normal for it to drip inside. If it is it's either iced up or your seal is failing.
Or, the evaporator condensate drain holes are plugged... - mboppExplorerI park a bit nose high so the drips run off at the rear.
- BobboExplorer IIIOn humid days, it looks like I parked in a lake! Perfectly normal.
- 2112Explorer IIIt is not normal for it to drip inside. If it is it's either iced up or your seal is failing.
- Dutch_12078Explorer IIIIt can be a bit confusing, but the water dripping outside is moisture that was removed from the air inside as a function of the cooling process. Lowering the humidity can help you feel cooler...
- jarata1ExplorerThanks
- tinstartrvlrExplorerYep.
- korbeExplorerYes only outside, not inside :)
About RV Newbies
