ol__grouch
Jul 06, 2014Explorer
It depends on which air suspensipn you want to add. There are air bags that add cushion. There are also air springs that REPLACE the leaf or coil springs. A lot of large trucks use these. Depending on how it is set up, you can add spring capacity but you will still be limited by your axle. Running a LOT of weight on a full load bearing axle, like a 1/2 ton, and you can easily snap an axle.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
