1. How tight do folks tighten your anode? (I use Teflon tape on threads and screw it in till finger tight, then little tiny two finger tap on end of socket wrench). 2. When not in use I drain...
A note for beginning RV'ers; The above only applies to Suburban water heaters. Atwood heaters do not use or need a sacrificial anode due to the tank material.
