path1ExplorerJan 26, 2018Anode questions.1. How tight do folks tighten your anode? (I use Teflon tape on threads and screw it in till finger tight, then little tiny two finger tap on end of socket wrench). 2. When not in use I drain...Show More
GordonThreeExplorerJan 27, 2018I'm another fan of leaving the anode out. As far North as I am, nothing is going to crawl inside the heater over winter.PTFE tape on the threads in the spring as mine are metal to metal.
