path1
Jan 26, 2018Explorer
Anode questions.
1. How tight do folks tighten your anode? (I use Teflon tape on threads and screw it in till finger tight, then little tiny two finger tap on end of socket wrench). 2. When not in use I drain...
memtb wrote:
Tightening: We have two units with different tank construction. One has plastic threads where anode rod screws in....I use your described method. One the other, metal threads.....I get a bit more aggressive with the tightening.
