path1
Jan 26, 2018Explorer
Anode questions.
1. How tight do folks tighten your anode? (I use Teflon tape on threads and screw it in till finger tight, then little tiny two finger tap on end of socket wrench). 2. When not in use I drain...
2. When not in use I drain mine (cold weather) and screw in finger tight.
Good or Bad??? What do you think?
Or what do you differently?
