path1
Jan 26, 2018Explorer
Anode questions.
1. How tight do folks tighten your anode? (I use Teflon tape on threads and screw it in till finger tight, then little tiny two finger tap on end of socket wrench). 2. When not in use I drain...
mobeewan wrote:jerryjay11 wrote:memtb wrote:
I also screw the rod back in partially. Never know what might enter. Once I found a dead snake in a residential house disconnected propane line.
A “Sewer” Snake? :h
Nope "DEAD" Snake.
It was in the 3/4" copper supply line that had been disconnected from the LP tank outside. Not sure what the little guy was trying to accomplish, but he was restricting the flow of gas.
Was it a "copperhead". :)
