wa8yxm
Jan 30, 2016Explorer III
There is always a reason to go with the heavier cord,, lower voltage loss.
Bus so long as you are not running A/C. Space heaters, Water heater or Microwave, I'd stick with the 12/3 In fact for battery maintenance that is exactly what I use.
I recommend the ones from Sears or K-Mart with the push button on the outlet end you need to push to plug in or unplug.. The plugs do not disconnect as easily as they do with other cords.. Since you need to push the release button.
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
