Joe417
May 05, 2015Explorer
Happy.camper, I agree with ScottG.
The sealer around the antenna is suppose to be white. It has lots of dirt stuck to it.
If you don't clean the old caulking before re-sealing it you could have a path for water as the new Dicor can separate from the "dirt/mold". I also use mineral spirits for cleaning old caulk.
I had a 93 Prowler that molded similar to yours.
I've experienced that once the rubber gets molded like yours it can't be scrubbed completely off. I too do not think it causes any problem other than not being bright white.
I put a coat of roof treatment on my current 5thW each year after it's spring cleaning. The roof still gets dirty through the winter but after 14 years it hasn't molded.
About RV Newbies
