path1's avatar
path1
Brake adjustment questions in the real world
In the real world...Questions about adjusting your brakes on towables (trailers and 5th wheels)
How often do you do it?
Do you adjust your brakes and call it good, or do you pull your hubs to check for grease and re-pack bearings and break out volt meter to check voltage?
(Just trying to see what other peoples routine is. I usually don't do anything until I feel some lose of stopping power or a wheel shows more temp heat than others.)
What's your routine?
