Ivylog
Sep 07, 2014Explorer III
You DO NOT NEED WD as the rear axle will still be lighter (have less weight on it) than the front axle. Why would you want to make the front axle even heavier and put more weight on the trailer tires? Why does Ford rate the hitch for 600 lbs WITHOUT WD? I'll answer that difficult question...BECAUSE YOU DO NOT NEED WD!
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
