Ron3rd
Mar 11, 2015Explorer III
As long as you have the 4.7 V8, you will be fine. I use to pull a 25 ft trailer, about 6,500 lbs fully loaded with my old 2000 Tundra 4.7 V8, which is basically the same drive train as what you've got, though the tow rating is a bit lower on the Sequoia because it's heavier than the Tundra. I see no problem with that trailer.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
