Matt_Colie wrote:
Nobody here has mentioned a real big issue.
If your RV has a problem and there is a virtually unlimited supply of water, it can all end up on your floor. And, that will be after the black and gray tanks overflow. So, unless you leave the dumps open all the time, that is a real risk.
Matt
Very true. The only time I have hooked up to campsite water was my four nite stay at Spearfish City Campground SD, and even then I shut off the faucet/spigot/whatever you call it, every day before I left to go touring in the rental car.
I don't even leave my pump on when I am not using the water.
Charles
