Mike43
Jul 14, 2014Explorer
Class C Toad
Buying a Class C. How many of you that own a Class C find that it is necessary to tow a car? Class C to be 28-30 feet. Thank you
hohenwald48 wrote:austinjenna wrote:If you are lucky enough to have the Marinco style power cable, it is simple to buy an extra cable that can be safely and securely run under the trailer and up to the generator. Eliminates the need for fancy and risky switching.
Thats what I did, keep it simple and cheap and it works well.
An extra cord will certainly keep it simple. However, it's pretty cheap and easy to simply add an ATS and let it take care of all the needed switching with no manual intervention. Either way will work. One's simply more convenient than the other. Your choice. And there's absolutely nothing at all risky about an ATS as long as you have the skills necessary to install one. :)
